at to mt pedal swap !!!!HELP PLEASE!!!!
poseidon1787
Post by poseidon1787 »
i pulled the tranny from my at front wheel drive and am getting ready to put my MT tranny in, i need to know , are there holes for the MT pedals in my AT legaacy, or will i have to drill new ones? i have searched but found no specific info on the installation of the pedals i need all the info i can get please help!!
gt2.5turbo
Post by gt2.5turbo »
there should be a diamond shaped rubber gromet on the firewall that is made for the clutch i believe. other than that everything elses should go through the holes already there.
Have you read the write up on the awd/mt swap? it is very very helpful
93 White Legacy Turbo Wagon: For Sale-ish
93 White Turbo Sedan: soon with a little more umf
91, funky brown purple gray color, legacy L Wagon: the "its so cheap i cant not pass it up" purchase to get me around when the others are down
THAWA
Post by THAWA »
What year is your car, and what kind fo pedals are you putting in? If it's hydraulic and your car is the first gen you don't have the holes for it. If it's cable you have a hole for it, it's kinda hard to see from the engine side, but you should be able to see the grommet from the interior side.
Rio Red 90 Legacy LS AWD 174k
Liquid Silver 92 SVX LS-L 88k
Post by entirelyturbo »
THAWA wrote:If it's hydraulic and your car is the first gen you don't have the holes for it.
You mean if it's a 1990 only :) 91-94's had turbos so they had the holes for the hydraulic setup...
*Formerly DerFahrer*
scuzzy
Post by scuzzy »
even the NA's had the holes for the hydraulic setup?
so it's just a matter of switching over to the new pedal setup and clutch slave system?
Yes...the holes are there.
Also....please post in the correct forum!
THAWA
Post by THAWA »
Show me one FWD 1st gen Legacy that has hydraulic clutch holes. Hell, show me any non-turbo 1st gen Legacy with hydraulic clutch holes.
206er
Post by 206er »
what do they look like? curious to see if mine has em.
THAWA wrote:Show me one FWD 1st gen Legacy that has hydraulic clutch holes. Hell, show me any non-turbo 1st gen Legacy with hydraulic clutch holes.
Are you talking about the holes to mount the clutch MC?
They should be there from 91 onward.
206er wrote:what do they look like? curious to see if mine has em.
These are the holes, it will have a single rubber plug over all three holes.
http://www.surrealmirage.com/subaru/ima ... P_3242.JPG
THAWA
Post by THAWA »
Yep those are the ones that are absent on all NA first gen legacys. I think they weren't standard on all subarus until 98 or 99.
