WRX intercooler hp gains?
Front, Top, Air, Water.
livestrong14
Post by livestrong14 »
Hey, I was wondering what I can expect in hp gains from a wrx intercooler on my 91' legacy turbo? I was told I could expect 20-30. All input is really appreciated!
91 SS -Carbon Bronze Pearl
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
91 Rio Red SS- RallyX Project
93 AWD Sedan- FOR SALE!
rallysam
Post by rallysam »
Eh... not a lot. I wouldn't look at it as a hp adder. Think of it as something that allows you to do the mods that really add power such as turning up the boost.
'00 Impr RS - sold
legacy92ej22t
Post by legacy92ej22t »
Yeah, the intercooler alone doesn't really add much.
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
Subtle
Post by Subtle »
I did the calculations years ago, but if memory serves-- at
around 90F ambient a good I/C will increase torque by about
15 %. :)
gt2.5turbo
Post by gt2.5turbo »
well when i added my ic i defintily felt slower cause it dropped my manifold pressure to 6psi but with my mbc set at 11psi give or take .5psi i definitily notice a difference. and hopefully once the fcd is in 13-14 psi will be a good time :)
93 White Legacy Turbo Wagon: For Sale-ish
93 White Turbo Sedan: soon with a little more umf
91, funky brown purple gray color, legacy L Wagon: the "its so cheap i cant not pass it up" purchase to get me around when the others are down
tasq
Post by tasq »
whats a good cheap MBC? How much PSI can you run with stock injectors?
- 94 Touring Wagon
- 05 Wrx Sedan
LaureltheQueen
Spelling Nazi
Spelling Nazi
Post by LaureltheQueen »
it depends on the turbo that you're running. You can get a good cheap mbc on ebay for next to nothing, but it all comes down to the features that you want(if you want any)
Laurel Tuning Stage 15
92 Touring Wagon 5MT 16G
tasq
Post by tasq »
LaureltheQueen wrote:it depends on the turbo that you're running. You can get a good cheap mbc on ebay for next to nothing, but it all comes down to the features that you want(if you want any)
I think I am sticking with the stock turbo for now... Id love to get a dual stage MBC, but I'm pretty sure those are alot more expensive :\
- 94 Touring Wagon
- 05 Wrx Sedan
LaureltheQueen
Spelling Nazi
Spelling Nazi
No clue on the stock turbo. The dual stage is DEFINITELY more expensive. If you don't really see a use for a high and low boost setting, then just get a regular mbc, you can get them for like $15 on ebay
tasq
Post by tasq »
LaureltheQueen wrote:No clue on the stock turbo. The dual stage is DEFINITELY more expensive. If you don't really see a use for a high and low boost setting, then just get a regular mbc, you can get them for like $15 on ebay
Thanks... Think ill be ok at like 11PSI on the stock injectors? :)
- 94 Touring Wagon
- 05 Wrx Sedan
LaureltheQueen
Spelling Nazi
Spelling Nazi
yes.
tasq
Post by tasq »
LaureltheQueen wrote:yes.
yays! thanks you :)
- 94 Touring Wagon
- 05 Wrx Sedan
