WRX intercooler hp gains?
livestrong14
Hey, I was wondering what I can expect in hp gains from a wrx intercooler on my 91' legacy turbo? I was told I could expect 20-30. All input is really appreciated!
91 SS -Carbon Bronze Pearl
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
91 Rio Red SS- RallyX Project
93 AWD Sedan- FOR SALE!
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
rallysam
Eh... not a lot. I wouldn't look at it as a hp adder. Think of it as something that allows you to do the mods that really add power such as turning up the boost.
'00 Impr RS - sold
legacy92ej22t
I did the calculations years ago, but if memory serves-- at
around 90F ambient a good I/C will increase torque by about
15 %.
15 %.
gt2.5turbo
well when i added my ic i defintily felt slower cause it dropped my manifold pressure to 6psi but with my mbc set at 11psi give or take .5psi i definitily notice a difference. and hopefully once the fcd is in 13-14 psi will be a good time
93 White Legacy Turbo Wagon: For Sale-ish
93 White Turbo Sedan: soon with a little more umf
91, funky brown purple gray color, legacy L Wagon: the "its so cheap i cant not pass it up" purchase to get me around when the others are down
LaureltheQueen
- Spelling Nazi
I think I am sticking with the stock turbo for now... Id love to get a dual stage MBC, but I'm pretty sure those are alot more expensive :\LaureltheQueen wrote:it depends on the turbo that you're running. You can get a good cheap mbc on ebay for next to nothing, but it all comes down to the features that you want(if you want any)
- 94 Touring Wagon
- 05 Wrx Sedan
- 05 Wrx Sedan
LaureltheQueen
- Spelling Nazi
No clue on the stock turbo. The dual stage is DEFINITELY more expensive. If you don't really see a use for a high and low boost setting, then just get a regular mbc, you can get them for like $15 on ebay
Laurel Tuning Stage 15
92 Touring Wagon 5MT 16G
Thanks... Think ill be ok at like 11PSI on the stock injectors?LaureltheQueen wrote:No clue on the stock turbo. The dual stage is DEFINITELY more expensive. If you don't really see a use for a high and low boost setting, then just get a regular mbc, you can get them for like $15 on ebay
- 94 Touring Wagon
- 05 Wrx Sedan
- 05 Wrx Sedan
LaureltheQueen
- Spelling Nazi
