A thread that I wrote on NASIOC shows the spring diameters for the different models, you could use that to verify fitment (look at the sticky thread in the suspension forum)
That said I would NOT use these. Cheap coil overs are usually bad news.
Thanks, All I need are some cheap springs, my subaru 1990 legacy L 142.000 miles is my second car so I dont want to go crazy with $$ on it what model will somewhat share springs with my car??
ciper wrote:Good tires will make more difference than these will ever make. Besides, wouldnt you rather spend the money to get new struts?
Agreed. I would expect far greater handling performance from a good set of KYB struts at stock ride height and grippy sport tires than this fancy-shmancy stuff...
