Would these work??
ilanpro
Would these work??
Post by ilanpro »
ciper
Post by ciper »
A thread that I wrote on NASIOC shows the spring diameters for the different models, you could use that to verify fitment (look at the sticky thread in the suspension forum)
That said I would NOT use these. Cheap coil overs are usually bad news.
ilanpro
Post by ilanpro »
Thanks, All I need are some cheap springs, my subaru 1990 legacy L 142.000 miles is my second car so I dont want to go crazy with $$ on it what model will somewhat share springs with my car??
ciper
Post by ciper »
If its your second car and you dont want to spend alot of money then why get them in the first place?
Good tires will make more difference than these will ever make. Besides, wouldnt you rather spend the money to get new struts?
(edited the top post, shipment changed to fitment)
Post by entirelyturbo »
ciper wrote:Good tires will make more difference than these will ever make. Besides, wouldnt you rather spend the money to get new struts?
Agreed. I would expect far greater handling performance from a good set of KYB struts at stock ride height and grippy sport tires than this fancy-shmancy stuff...
1993 Citroën XM Turbo C.T.
1993 Ford Spectron XL-T
1991 Fiat Croma 2.0T i.e.
