cam sproket identification marks
ars14
Post by ars14 »
Ok, so looking at the front of the engine, the drivers side cam sproket has an L on it,and the passenger has an R. I havent pulled them off yet so I just wanted to know if It is based on siting in the drivers seat?
dumb question I know
'94 Legacy L Wagon
no mods, just a driver
Easy way to tell....the driver's side has protruding "bumps" on the back for the cam sensor.
ars14
Post by ars14 »
thanx, i will check tonight when I get home, has anyone tried using a sproket wrench like in the haynes manual, or just a strap wrench, I wonder how easy the cams turn with out the sprocket on them
'94 Legacy L Wagon
THAWA
Post by THAWA »
Everything on the car is labeled such that you are viewing the car from behind or inside the car, I believe all cars are like this. They don't turn very easy if there is load on them.
Rio Red 90 Legacy LS AWD 174k
Liquid Silver 92 SVX LS-L 88k
ars14
Post by ars14 »
i just used a strap wrench so they came off pretty easy, they did turn a little, but the should all line up with the marks
'94 Legacy L Wagon
