Bad Gas Mileage?
Bad Gas Mileage?
Not sure where to post this, It seems that my car is down to a 1/4 tank, with only 150 miles on the trip. I drive quick, but it shouldnt be this bad. It is also a stock ej22t. Anyone have a good guess what it should be getting after 100k or where I should start looking? Thanks in advance.
Hmm I'm trying for turbo back but I will get eaten alive after shocks, brakes, and who knows what with the back diff.
Right now I am thinking injectors, or mebe O2 sensors. I don't have a air fuel gauge or anything nifty yet. I didn't think about the exaust, but before my truck's cat went the mileage was getting really bad.
You have a 15 gallon tank. Being at a quarter tank with 150 miles might mean that your fuel gauge is malfunctioning, a common issue. try filling your tank to where you can see the gas in the fill tube and check what kind of volume you put in there. That will give you a better idea of what you're getting.
--Scott--
1991 - Rio Red SS
1991 - Rio Red SS
16.610 Mpg. With probly the first quarter tank being highway, the last city. Should be around 249 for a tank so I am guessing my gas gauge is screwed. That and it takes like 15 sec to get up to full. I am guessing its going to be the float or something because the gas gauge doesnt shake or jump. I did notice it read a 1/8 difference up then down then up. Half of the problem solved.
Yeah, hard pulls kill your gas, that's for sure. I believe there's a pair of send recieve units that have been usual suspects in this case. My gas gauge dips way down below empty at times. I'll have 260 mi a lot of times when I go to fill up and only wind up putting 10 or 11 gallons in.
--Scott--
1991 - Rio Red SS
1991 - Rio Red SS
snowboarded
Yea my gauge is off from time to time also. Some times, it functions just fine. I haven't found anything to link why it acts up sometimes.
I think the gas gauge malfunctions and the speedo needle wobble makes our cars cute. lol.
[quote="Manarius "]Only flamers will get those. [/quote]
[quote="All_talk "]How many WHP will that give me? :)[/quote]
2010 Subaru Impreza 5mt 5 door
legacy92ej22t
My gas gauge has always worked perfect. Except that the gas light comes on at like an 1/8th of a tank for a few minutes and then comes back on when it's actually supposed to.
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
Manarius
Yes. '91's have lights. Drive it down to around 13 gallons (That's about 260-280 miles for me) and you'll see the little light come on. I do believe it works regardless of how the gas gauge works (because my gauge doesn't work either).Busdriver wrote:I don't think my wagon has a light, at least nothing lights up when turning the key to the on position, and I don't think I ever saw a spot for it...
91 have lights??
scottzg
Mine does this too.legacy92ej22t wrote: Except that the gas light comes on at like an 1/8th of a tank for a few minutes and then comes back on when it's actually supposed to.
Also drops way down for a while when i go over ~90 for any length of time.
No, it does not come on.Busdriver wrote:Sweet thanks Manarius,
is this light 'sposed to come on when the ignition is on like all the other warning lights?
snowboarded
