Quick ?
Don't know....that's a different animal.
I made mention to the JECS sensor because it is a direct bolt on for our cars.
Josh You told me once in a pm that there was an MAF that read more g/s or something. Is that the same jecs one that came on my 1.8L impreza?
2011 Mini Countryman S All4
1970 Honda Ct90
2001 Forester S of Doom - mowed down by a Cummins
1994/5/6/01/02/03/04/06/07/08 Impregacy OUtback SS STi Type R money pit- NEW RALLYCAR!!
1970 Honda Ct90
Yes, the black JECS MAF is the one that can read more. It's the MAF sensor that came on all the first gen n/a AT legacies and all the n/a 92-94 MT legacies
Good!
May I make a suggestion though? Get a higher-ratio RRFPR and put a restrictor and bleed valve in its pressure reference line. Then you can dial your fuel enrichment much as an MBC allows you to dial your boost.
That's how I have mine set up. I don't even know what ratio my RRFPR is, but I'm only feeding it a tiny bit of the manifold pressure signal.
Are you going to switch back to the NA injectors and remove the MAF trim?
screw you mouth564, I was hoping there would be some insite from one of the geniuses we have on here and I open this to see your stupid post.
1970 Honda Ct90
1970 Honda Ct90
