Weird electrical issues
94L_wagon
Post by 94L_wagon »
Hi all,
I have been having odd electrical problems for a while now, but recently they have been getting worse. These are the symptoms, least interesting first:
- Radio reception is poor
- Rear wiper is sometimes really slow - almost stops, other times it is fine.
- AC won't turn on sometimes. There is no change in revs when at idle so the compressor is not activating. It is very cold when it works. I tried replacing the relays - no difference, but the other relays were used too - so they may be bad also knowing my luck.
- Sometimes the car won't start. There is a click, then nothing. If I turn the key again it is usually fine, and starts on the first stroke as though nothing is wrong at all. Recently this in particular has been getting much worse.
I am at 93xxx miles, but the PO used to do 2x5 mile journeys a day for 8 years, so the starter has had a bit more wear than usual. I see the wearing of starter contacts is pretty normal...
The battery seems OK because when the car clicks it fires right up, and the charge light never comes on, so I think the alternator is OK.
Any suggestions greatly appreciated :-).
Thanks,
94L Wagon (AWD) - bone stock, 136k miles at July 08. Manual (sold - along with my soul to BMW).
Manarius
Post by Manarius »
1. Your starter contacts are toast. My car did the exact same thing when the starter was cooked.
2. I think your radio reception/Slow rear wiper are related. Maybe your alternator is not putting out so much anymore..or you've got a grounding issue.
3. For the A/C....are you sure the plug on it is plugged in the whole way? (I don't know a lot about the A/C system)
94L_wagon
Post by 94L_wagon »
Hi Manarius
Thanks for confirmation on the starter issue. I will make sure I order a new one pronto. I just wanted to be sure before throwing parts at it.
I am also going to clean up the battery terminals and sand all the grounding contacts before worrying about the other issues. There are a couple of Legacys (automatics so wrong starter) in my local pick and pull so I might go and grab an alternator and possible a rear wiper motor as well just so I have them handy. One of them has a really fresh looking alternator on it.
Thanks,
94L_wagon
Just a closing statement for ppl searching the archives...
Post by 94L_wagon »
Cleaning the battery terminals and all the grounding connections has helped - for now.
AC operational again (with my original relays - pick n pull ones seem to be bust) wiper back up to speed and she starts first turn of the key again.
I suspect that this is a temporary fix due to slightly better voltages reaching the relays and starter contacts, so I will be prepared to replace them some point later when this flares up again.
