I have been having odd electrical problems for a while now, but recently they have been getting worse. These are the symptoms, least interesting first:
- Radio reception is poor
- Rear wiper is sometimes really slow - almost stops, other times it is fine.
- AC won't turn on sometimes. There is no change in revs when at idle so the compressor is not activating. It is very cold when it works. I tried replacing the relays - no difference, but the other relays were used too - so they may be bad also knowing my luck.
- Sometimes the car won't start. There is a click, then nothing. If I turn the key again it is usually fine, and starts on the first stroke as though nothing is wrong at all. Recently this in particular has been getting much worse.
I am at 93xxx miles, but the PO used to do 2x5 mile journeys a day for 8 years, so the starter has had a bit more wear than usual. I see the wearing of starter contacts is pretty normal...
The battery seems OK because when the car clicks it fires right up, and the charge light never comes on, so I think the alternator is OK.
Any suggestions greatly appreciated
Thanks,
