Moderators: Helpinators , Moderators
waldo320
Posts: 326 Joined: Wed Jan 05, 2005 1:41 am
Post
by waldo320 » Thu Nov 24, 2005 12:22 am
Hi all I have a bit of problem I am putting on a 91 turbo manifold on my 94 NA and the left manifold elbow is rubbing my thermostat and every time i try to tork the manifold I get a coolent leak do to the added pressure. Two options in my book get a half inch peace of steel and shim the manifold or shave some of the thermostat. If you have any another tricks up you sleves they would be most helpful.
napphappy
Posts: 512 Joined: Fri Jun 03, 2005 12:57 am
Post
by napphappy » Thu Nov 24, 2005 12:38 am
Im guessing you are talking about the Exhaust manifold. If so, you might try posting in the Exhast forum. Sorry I have no expirence with this problem.
1997 White BG Ltd 5MT, EJ22T with Wiescos, EJ20R Heads, Two large dents R.I.P
1995 Impreza EJ22T DOHC Hydra EMS, 20g, EWG, 3in APS TBE, AWIC
Posts: 12517 Joined: Sun Nov 03, 2002 2:13 am
Post
by vrg3 » Tue Nov 29, 2005 8:09 pm
The Right Way to handle this is to switch to a water pump and thermostat housing for a turbo model.
waldo320
Post
by waldo320 » Tue Nov 29, 2005 8:39 pm
cant do that would need a turbo bolock cause the thermostat outlit is a part of the block
Post
by vrg3 » Tue Nov 29, 2005 8:59 pm
No it's not.
Posts: 27936 Joined: Tue Oct 15, 2002 11:37 am
Post
by Legacy777 » Fri Dec 02, 2005 3:24 am
Vikash is right....you can swap to a turbo pump. There is an extra fitting you'd have to cap off, but that shouldn't be too big a deal.
