Buildup prep
willmoodom
Buildup prep
Finally got a 22T( complete w/sesors and wiring) at the junk for $150. But that is only the beginning for me. Rebuild is mandatory. Already sourced Forged Pistons. Any recommendations for gasket kits? Subaru,felpro.......? Im looking for quality and strength. what brand of rings and bearings do you thoroughbreds go with? I have a 95 Impreza L 2.2 w/auto and awd. This is and will be my everyday driver. I'm hoping to put 270-300 to the ground. Thanks.
willmoodom
douglas vincent
Go stock Subaru. Unless you want SERIOUS power, and possible SERIOUS problems, ie bad gaskets, just go OEM.
Here are Import Performance Parts.
http://www.importperformanceparts.net/i ... ubaru.html
I did.....I pretty much rebuilt the internals to stock, and used stock components.
I used the subaru gasket kit, as it has all the gaskets/washers, etc that you need.
You can view my project here
http://www.main.experiencetherave.com:8 ... ges/ej22t/
