Well where to start well even on my old vf10 runnin more that like 10-12 psi of boost my engine would like bogg. But now with the vf22 it way worse coz i cant stop the turbo from pullin 16psi!!! lol soo need to work this out quick soo i can take my turbo for a proper spin.. just read about the maf signal being over 4.4volts.. maf is the air flow meter right?? does anyone know which wire is the signal??
thank 4 any ideas in advance..
VF22!! Fully Installed.. 1 problem.. missfire?? or boggin
if your wheels arnt smokin your not driving it fast enought!!!
What would your coils have to do with it? hack0r do you have any form of boost controll? Because you need it.
And it shouldn't bog, the computer should cut fuel when the turbo is pushing that much air. Unless you have some kind of fuel cut defender.
1988 4Runner RIP
2006 Suzuki DRZ400sm
2007 Miata
1994 Miata
2003 WRX Wagon
2016 Mazda 3
1988 4Runner RIP
2007 Miata
1994 Miata
2003 WRX Wagon
2016 Mazda 3
BAC5.2
Plug gap causes misfires. Check that, and simply replace the plugs.
If you are SURE it's a misfire, that's a good chance of being the reason.
the bogg sounds like fuel cut allthough i've only ridden in a car once when this happened. the whole car wound down and it was kinda rough, but once the boost sgot back under 12 psi, it was fine.
this link is on the board somewhere...i'll just post it because i was looking at it.
http://www.graphics.cornell.edu/~v/fcd/
beat ya to it vrg3
beat ya to it vrg3
stupid electrical work...
He said it was happening a little with his old turbo as well, so its probly not fuel cut. When I hit fuel cut, the whole car jerks like I hit a wall. Then it goes again.
Hack0r: Pull your plugs, if they look alittle fouled- replace them. Plugs are cheap. Its a good time to go one step colder anyway(BKR7E I think)
If you replace the plugs and nothing changes
Check the coil. To do so:
Unplug wiring connector and check resistance between the center wire and the two outside wires in the connector. you should get about .7 ohms between each.
Then check the secondary coils by measuring resistance between the parallel outputs(where the plug wire attaches) i.e. between 1&2 the 3&4. you should get about 13.8K ohms.
Well some things you might try anyway.
1997 White BG Ltd 5MT, EJ22T with Wiescos, EJ20R Heads, Two large dents R.I.P
1995 Impreza EJ22T DOHC Hydra EMS, 20g, EWG, 3in APS TBE, AWIC
yeah i have the fcd installed
way ahead of you..
thanks for the quick responce. Will do that thanks guys other think..
Now i have installed this big turbo
.. hopefully a good idea?? lol i have boiling my blodly radiator water.. after i turn the engine off.. does anyone know how the sti ra stops this?? like i left my turbo timer on idle for like 6 mins!! came out after it had turned off.. and the over flow had water boiling out!!! and its emptyin my whole top tank every time!!! i can hear the water boiling out from the top of the turbo.. i have heard of ppl disconneting the water to the turbo has anyone done this??
thanks
Hack0r
thanks
Hack0r
ohh the other thing is the fcd.. right.. i thought maby i was hitting fuel cut soo i mesured the voltage it was sending to the ecu.. and it was only after i hit 4.4 or 4.5 it would bog?? you recon its fuel cut?? still think part of it is like plugs or coils.. ohh by the way thanks for the resistans number for that.. i have 2 service manuals for my car.. and none of them telll me that!! argh! lol
