Replace 95 Legacy 14 inch wheels (steel)
I was hoping to get some advice on getting some affordable used alloy wheels to fit a 95 Legacy. Is there any benefit (other than looks) to go with a 15 or 16 inch wheel? It sounds like WRX used wheels are fairly common. Can I find these with the same offset as my Legacy (not sure what the steel 14 inchers offset is).
Alternatively, any source for Moon discs that would fit the steel wheels?
mostly because this is a "A forum for 89-94 BC-BF Legacy Owners and Fans" as per the top of every damn page on this website. 95 wheel specs are the same though.
larger wheels let you run larger brakes and lower profile tires w/o changing your gearing.
wheels are 5x100.
wheels are 5x100.
Damn brother, harsh. Funny as hell but harsh lolscottzg wrote:mostly because this is a "A forum for 89-94 BC-BF Legacy Owners and Fans" as per the top of every damn page on this website. 95 wheel specs are the same though.
2007 Ducati 800ss - Current
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru GL Wagon
1987 Subaru Loyale
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru Loyale
stock offset is around +53-55mm
scott...be nice now.....
I just got a set of 15 x 7" Ronals that were OEM on a Jetta. They have 38mm offset and really fill out the fender nicely. There is no rubbing with 195/60-15s as the inside edge of the wheel in within a couple mm of the stock rim. They fit so snugly on the hub and lugs, like they were made for a Legacy. $60 on ebay. There are lots of VW takeoffs out there cheap. I put some photos in my SVX locker.
http://www.subaru-svx.net/photos/user.p ... alex|32653
