Alternator swaps?
Threshld1
Alternator swaps?
Post by Threshld1 »
so who can tell me if there is a difference between our alt mounts and the newer wrx/sti mounts? say i can get a sti alt for cheap can i swap it out for my failing one?
also how does this hold to power stearing pumps, both need to be replaced soon and i can get both cheap from an sti
Splinter
Post by Splinter »
AFAIK they are identical
Im getting a rebuilt WRX alt in the mail in a few days.
The power steering pump mount is different, I'm pretty sure. The fittings may be different on the pump as well. And remember that the STi pump has a remotely mounted reservoir.
The alternator mounts should be the same.
You will run into issues with the length of the main power wire not being long enough. Also the electrical connector/plug will not be the same.
Threshld1
Post by Threshld1 »
blast i knew it wouldnt be this easy... well its on the way for $80 so ill just make it work
the main power isnt an issue, was gonna upgrade it for the future audio anyways, have plenty of 4awg and fuses around.
any suggestions on the connector? or am i just gonna have to start hacking wires (not my first choice)
I'm pretty sure it's a 2-wire setup with rpm dependent turn on. If so, you just wire up the sense & light wires to the correct sense & light wires for the sti alternator.
it shouldn't be a big deal.
I can help ya with wiring once you get the alternator and see how it's setup.
