so who can tell me if there is a difference between our alt mounts and the newer wrx/sti mounts? say i can get a sti alt for cheap can i swap it out for my failing one?
also how does this hold to power stearing pumps, both need to be replaced soon and i can get both cheap from an sti
Alternator swaps?
The alternator mounts should be the same.
You will run into issues with the length of the main power wire not being long enough. Also the electrical connector/plug will not be the same.
Threshld1
blast i knew it wouldnt be this easy... well its on the way for $80 so ill just make it work
the main power isnt an issue, was gonna upgrade it for the future audio anyways, have plenty of 4awg and fuses around.
any suggestions on the connector? or am i just gonna have to start hacking wires (not my first choice)
I'm pretty sure it's a 2-wire setup with rpm dependent turn on. If so, you just wire up the sense & light wires to the correct sense & light wires for the sti alternator.
it shouldn't be a big deal.
I can help ya with wiring once you get the alternator and see how it's setup.
