Legacy Brakes same as Impreza?
I can't find the Star Adjuster to back off my rear shoes from the Drum I see 2 rubber plugs one right below the air bleeder and one in the lower right corner.
It's a pain to adjust....screwdriver is your best bet.
Yeah....some of the rotors I've used are like that. I've asked about turning the drum, and the one place said they couldn't. So either they can't or they wouldn't.
I just backed off the parking brake so that it wouldn't rub.
When adjusting the parking brake, make sure to put a few lug nuts on and tighten them so the rotor stays true and you're not trying to fight a problem that's not there.
