clutch bearing questions ( replacement)
dscoobydoo
OK, so the wrx clutch/flywheel is going in soon. So, do I get the corresponding WRX bearings or stay with SS ones? I figure on getting OEM ones unless you think I need better ones.
Yes I have too many Subarus
No you can't have one
05 GD-STI
01- RS- Swapped-07 STI
00- GF
05 GD-STI
00- GF
The throwout and pilot bearings are (should be) the same.
If your SS ones are new, I'd keep the SS ones, however if your SS ones are old and have a few miles on them, I'd replace them since you have everything apart.
