Big Help needed with brakes!
The brake line banjo bolt is whatever size wrench fits it, I think 13 or 14 mm, just try different wrenches until you hit the one that fits. You shouldn't need to take it off unless you plan to work on the caliper away from the car or rebuild it. Yours needs rebuilding since the boot is torn. If you do that, rig up a way to gently clamp the brake line so the fluid doesn't all leak out. Also, be careful pushing any pistons back in with other calipers loose or overflowing the reservoir. And don't go anywhere near the brake pedal while you have stuff apart. Good luck. I am too far from you or I would be willing to help, but without getting your calipers rebuilt it's kind of pointless.
'94 Legacy Touring wagon. Quicksilver metallic. WRX rims, Whiteline ALK, SS brakelines, GR2s, alum. coolant tank. Gone, but not forgotten
'99 NSX, Alex Zanardi edition, #11/50. All stock & red 2 go
'05 Corolla XRS
'05 Corolla XRS
1-3-2-4
Ok here is the Deal I got a new Caliper for $126.11 I have to pick it up tomorrow since it was not in stock.
Now These Banjo bolts... When I take it off Can I expect a Mini Old Fathful or what? If I put it in a upright postion will it still leak fluid?
I checked the level this morning it drained all of my fluid from the Pad Passenger side (being replaced tomorrow)
So... Now when I have the new one in hand, what is the order I should do things?
i want to be careful The car is a 95 so I want to be nice to the brake lines. And yes 14mm is the Correct sizes for the bolts.
I guess I will go to sears and pick up that 159 pcs. tool Kit, I'm sure I will be thanking myself forever on that.
it's been a long ride but Calipers can go out on their own anyways right? i guess I was just speeding things up.
You may have a core charge (they will want the old one). I would probably rebuild the other side since it's just as old & crappy as this one. Make sure you understand the slide pins & where the caliper needs to be before you go putting things too far together. I'm guessing the new caliper will come with new washers for the banjo bolt. Use them, after you get everything mechanically together first (i.e.- hook up line last after you have everything else comfortably together). You will need to bleed a lot. Don't let reservoir run out. Don't forget high temp grease on silver clips where pads will move inward toward rotor. The new pads usually come with a little packet of it. Copper color for the Subaru pads, I believe. Make sure the pins get some & are sliding smoothly too. They won't move super easily, but hand pressure should be enough to slide the caliper in on the pins and compress those little rubber boots. Make sure the boots are seated on each end, they have a little lip inside the hole that helps them stay put.
'05 Corolla XRS
'05 Corolla XRS
1-3-2-4
One tiny tiny issue, the caliper I'm taking back for the core charge.. Well it has my New brake pad stuck in it, and thats the one I can't get to slide out.. I've used the C-clamp on the Caliper Bracket and the Caliper Body, it does not move period.
All I need it to move in a few Millmeters and I could drop it out.
But I guess I will just take the brake line off in the morning and try working on it away from thr car. The Brake line has a TON of air in the lines right now.
As How I understand it now..
I get new Caliper in hand and this is the steps as far as I know...
Mount new Rotor to wheel Hub
Mount New Caliper on the Kuckle
Unbolt the Caliper Slide Pin (Lower one)
Lift up the Caliper Bracket
place the Inner and Outter Brake pads on the Caliper bracket
Lower the Caliper back down and replace the bolt for the Caliper
Hook the banjo bolt up
fill brake fluid
bleed brakes
check brakes on and side road or off street away from the highway.
fill brake fluid
bleed brakes
after you put on the rotor put on the caliper bracket. Then place pads (with shims & clips) down in bracket & wiggle caliper into place. The caliper bracket stays put, for a pad only job you would never touch it. Just pivot the caliper up on the top bolt with bottom bolt out. be careful not to confuse bottom caliper bolt with brakeline bolt. Make sure piston is all the way back in 1st & that caliper is pulled toward you (away from centerline of car) on slide pins so that it will have enough room to clear new pads on both sides of rotor. You shouldn't be able to see the pins & the 2 little rubber accordion boots will be scrunched down. Sounds like you have it down right otherwise. If you have a vacuum bleeder or pressure bleeder, it will help. If not, get a friend to help. Good luck.
'05 Corolla XRS
'05 Corolla XRS
1-3-2-4
I'm not going to touch the drivers side until I put some lube on the slider pins, it's just as hard to move as the passenger side.
but for the most part I understand it now.
I still have the rear drums to do, those should be here vis ups on Feb 3rd.
I have to put some lube on those Metal brackets that the pads slip onto.
your brakes show a lack of maintenance which is why the slider pins are trashed. Also the popped piston probably resuted from the pads wearing all the way through the lining and maybe even the backing plate falling out (as can happen particularly on Hondas with worn-out pads). This lets the piston out too far and the seal tears off.
I would not even consider reassembling without replacing the other caliper as well. Brakes like to be worked on in pairs, particularly when things look that bad.
http://bbs.legacycentral.org/viewtopic.php?t=1196
http://bbs.legacycentral.org/viewtopic.php?t=17062
1-3-2-4
Ok everything is in and I did the bleeding of the system... I have a very mushy feel in the brakes, but I have a feeling it's due to the worn out rear bake shoes, and as soon as Ups brings the rear drums (Feb 3rd) I can start on the rears.
So anyways I took it on the road and did a few stops from 30 Mph did ok, But I get the hit brakes smell, not sure if thats normal or not... So I get home and I take the driver side wheel off and I look at the pad I'm not sure if their is a way to read a new rotor but I have a little bronzing near the hub and the rest looks good, I can still see the Cross hatches so maybe it's not fully seated yet.
http://www.stoptech.com/tech_info/wp_bedintheory.shtml
explains how and why brakes are bed in. That burning brake smell means you're getting there.
1-3-2-4
Nice read, I'm almost therejamal wrote:http://www.stoptech.com/tech_info/wp_bedintheory.shtml
make sure your caliper isn't stuck and that's causing the burning smell when the pad doesn't release from the rotor. Does it pull to one side? or smoke from 1 side?
'05 Corolla XRS
'05 Corolla XRS
1-3-2-4
Brakes don't pull to one side.. But here is something odd.. I drove around yesterday eevrything was fine, but today I leave for work and the Brake light came on...tonflo wrote:make sure your caliper isn't stuck and that's causing the burning smell when the pad doesn't release from the rotor. Does it pull to one side? or smoke from 1 side?
I pull over and I look at the fluid level it's at MAX.
My Petal is still Mushy and I think it's Because of the Rears, they need to be done. Now I wished I did overnight for the drum brakes.
I have the shoes sitting right here next to me.
I can't Lock up the Fronts at all Dry or wet pavement.
this is what i have used on my lightning and will be using on my legacy
http://www.motiveproducts.com/02bleeders.html
works great only need one person
1998 Subaru Legacy Brighton Wagon
(28mpg, leaks oil, rear door latch broken, 137hp)
2002 Ford SVT F-150 Lightning
(14mpg, deathtrap in snow, 405hp)
I don't think you should use those cheapo "power bleeders." They use air to pressurize the brake fluid, which means they'll force moisture into your system.
Real professional power bleeders don't use air to pressurize the fluid.
Vacuum, not pressure, is the way to go, in my opinion.
Really? So when you actuate the plunger using the handle, no air is compressed? My mistake. That device be a lot fancier on the inside than on the outside.
To me it looked like a branded version of the homebrew power bleeders people make with garden sprayers.
it is similar but built properly as to not blow air into the brake system....UNLESS YOU LET IT GO EMPTY.....it is a pressurized tank but the only thing that will come out of it is pure fluid after the first pump of two
