Finally hooked up the launch control on the MSD DIS-2
biggreen96
Post by biggreen96 »
oh my sweet baby allah!
I have it set for 3500 and it makes ~2 lbs of boost when i floor it :-D
I mounted a little unassuming button in that panel next to the ebrake to enable the lower rev limiter.
hehe i never knew a little button could bring so much joy!
Hehe, nice.
I hooked mine up to a second stock cruise control button.
biggreen96
I rally really wanted to hook mine up to the "cancel" of the cruize control so i could have both hands on the wheel but it looked a bit more difficult than placing a new button. what are your thoughts? Im unsure of how that circuit works.
Have you removed your car's cruise control?
You should be able to use the "cancel" switch with some work. What year and model do you have exactly?
DLC
Post by DLC »
That's my old car vikash, and I never hooked the CC up after the trans swap (among other things :) ). That's cool that you got the launch control hooked up, I'm sure it's fun.
Legacy Central
Okay... 93 Touring Wagon. I'll try to look up the wire colors you need this evening. Bump this thread if I forget.
BAC5.2
Post by BAC5.2 »
Launch Control in V's car was a lot of fun. That thing launched like CRAZY!
Post by 555BCTurbo »
I am gonna need it once I put a Holset on my motor :shock:
biggreen96
bumpy
sammydafish
Post by sammydafish »
Do you have a DIS-2 Plus (the new one with dials not switches) if so, are you retarding the timing too?
It seems like my DIS-2 just died... I gotta check the wiring, but seems like it might have crapped out.... kinda dissapointed about that.
- Junior
90L Wagon EJ22E on Toyota CT-26 boost -- Crushed!
95L Wagon on T3/T4 boost :)
www.trdsupra.com [b][url=http://trdsupra.com/library/forsale/]Cheap parts![/url][/b][quote="Imprezive"]alright, I give up, I'm going to NASIOC...[/quote]
biggreen96 - D'oh, sorry... I'll try to remember to check tonight. You gotta bump the thread in the evenings when I'm at home!
Junior - Really? They don't fail often... Do check the wiring. :(
biggreen96
nope, I have the one with switches.
DLC
Post by DLC »
That one I got in 01, August I think, right before my Japan trip. Got a ticket right after I installed it :)
Legacy Central
magicmike
Post by magicmike »
can someone explain what this does?
2007 Ducati 800ss - Current
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru GL Wagon
1987 Subaru Loyale
Thanks for bumping the thread, Mike!
Okay, look under the dash for a 5-pin connector shaped like this:
Code: Select all
 ___   ___
| 1 |_| 2 |
| 3  4  5 |
|_________|
I think it's with the other connectors coming from the steering column. The car side of the harness connector is black plastic; I don't know what color the other side is.
Pin 1 should have a red-with-green-stripe wire on it.
Pin 2 should have a light-green-with-black-stripe wire on it.
Pin 3 should have a green-with-red-stripe wire.
Cut the red-with-green-stripe wire and make sure that the side going into the steering column does not have +12v on it when the ignition is on. Connect this wire to ground.
Then splice into either of the other two wires and connect it to the DIS-2's blue wire.
Mike - The DIS-2's launch control feature is basically a low soft rev limiter. So you put a push-button switch between that wire and ground, and when you hold that button down you can floor the pedal and the engine will rocket up to whatever rev limit you've chosen. Once it reaches that speed, the DIS-2 starts randomly cutting spark one cylinder at a time to prevent engine speed from increasing.
magicmike
Post by magicmike »
ahh ic. I do a similar thing with my left foot on the brake in my 4eat.
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru Loyale
Yesh. From the factory automatics allow you to make boost without moving.
biggreen96
awesome thank you man. dang now i will have a button that does nothing. scratch that, intercooler spray.
Penguin
Post by Penguin »
Ok I am on this "do it with factory subaru stuff" thing right now...
I wonder if you could get the same "boost without moving" effect that the auto has on a 5 speed if you mod a hill holder valve from a loyale/imp?
hummmmmm
-Penguin
1978 DL+GL 4WD Wagon (only ever seen 4!!!)
1993 Turbo White Wagon (EJ22t DOHC FMIC, 4.11 5 speed swap with wrx LSD)
1996 Impeza Outback Sport (wifes car)
2002 Suzuki GSXR-1140 Bored and Stroked
(just to much to list... 202mph on radar @ Daytona)
It's not that simple. The reason you can do it on an automatic is that the engine and transmission are only loosely coupled through the torque converter. Unless you slip the poop out of your clutch, you can't load the engine with the weight of the vehicle without actually moving the vehicle.
biggreen96
I finally had some time to play with my electrics today so I decided to mess with this.
Code: Select all
 ___   ___
| 1 |_| 2 |
| 3  4  5 |
|_________|
On mine the car side plug is white, the column side plug is black.
this is where a problem is, the red-with-green stripe coming from the car side is hot, and activates the horn when I ground it. Scared to bejeezus out of me haha!
I tested it with the plugs disconnected.
