I have it set for 3500 and it makes ~2 lbs of boost when i floor it
I mounted a little unassuming button in that panel next to the ebrake to enable the lower rev limiter.
hehe i never knew a little button could bring so much joy!
Code: Select all
___ ___
| 1 |_| 2 |
| 3 4 5 |
|_________|
On mine the car side plug is white, the column side plug is black.vrg3 wrote:
Okay, look under the dash for a 5-pin connector shaped like this:
I think it's with the other connectors coming from the steering column. The car side of the harness connector is black plastic; I don't know what color the other side is.Code: Select all
___ ___ | 1 |_| 2 | | 3 4 5 | |_________|
this is where a problem is, the red-with-green stripe coming from the car side is hot, and activates the horn when I ground it. Scared to bejeezus out of me haha!
Pin 1 should have a red-with-green-stripe wire on it.
Pin 2 should have a light-green-with-black-stripe wire on it.
Pin 3 should have a green-with-red-stripe wire.
Cut the red-with-green-stripe wire and make sure that the side going into the steering column does not have +12v on it when the ignition is on. Connect this wire to ground.
