how much boost?
how much boost?
What would be the highest safest boost with a vf12 in a '91SS, no IC, 3"CES TBE, K&N panel filter? Don't want to break anything. Also, what would your guess be for crank HP?
I think I ran 9 or 10 psi intercooled on a stock exhaust without the muffler. That's about what I'd run with my exhaust and no intercooler, at the very most. A VF12 flows a lot more air than the stock VF11, so I'd suggest running it at wastegate boost (around 8 or 9psi probably) and you should be OK. I run my 16G at wastegate boost around town, and it's kinda quick.
BHP at 9 psi on a VF12 would probably net you close to 190 or so BHP.
I agree with Phil...the VF12 flows a considerable amount more air volume than a VF11, and running it non-intercooled with anything more than wastegate boost is kinda playing with fire, so to speak.
You should pick up an AWIC and a walbro pump, then you can start having fun![Razz :P](./images/smilies/icon_razz.gif)
Why aren't you using an intercooler with the vf12? I'm not sure if you could have a high enough pressure to overcome the size of the turbo and still be unintercooled.
Rio Red 90 Legacy LS AWD 174k
Liquid Silver 92 SVX LS-L 88k
IC first or turbo first?
The opportunity to purchase a vf12 came up, and I will be picking it up this weekend. The rear cam seal weeps and will have the turbo out to make it easier to get at the cam seal to replace it. Thought that would be a good time get the vf12 in. Getting an intercooler is a step in the evolution of enjoying this car. That is why my intent is to get the vf12 in there at this point. IC first? Bigger turbo first? It just happens that I will have the turbo in hand first. Is it a fatally flawed plan? Also, currently do not have a boost controller installed, and will have a boost gage in before I replace the vf11 or at the same time.
I think it would be better to put an intercooler in at the same time as the vf12.
what CHP ballpark would 190 BHP put you in? 250 CHP?BAC5.2 wrote:I think I ran 9 or 10 psi intercooled on a stock exhaust without the muffler. That's about what I'd run with my exhaust and no intercooler, at the very most. A VF12 flows a lot more air than the stock VF11, so I'd suggest running it at wastegate boost (around 8 or 9psi probably) and you should be OK. I run my 16G at wastegate boost around town, and it's kinda quick.
96 Impreza L sedan
97 legacy outback limited
00 Impreza RS sedan
00 Impreza RS sedan
BHP = CHP.
WHP < BHP.
Compare 190BHP to the claimed 160BHP. You'd be lucky to see that jump.
WHP < BHP.
Well, what I'm saying is, you're going to have to redo the pcv hoses, and the turbo to intercooler tube anyway, so why not throw an intercooler into the mix also? I'm sure you could find a WRX one for less than 100 bucks.
heh im gonna agree too. if you are changing the turbo, you might as well get an intercooler on it too since your alrdy there. plus isnt the vf12 sort of in between a td04 and td05? i wouldnt run that any higher than stock boost either. right now im boosting close to 11-12 psi un-intercooled on my vf11. i wouldnt go any higher than that on my setup.
00 5MT AWD 2.5 RS - New Project
Lots of discussion on this already. I think almost everyone would agree you may as well do the WRX intercooler if going topmount. Frontmount's better. ![Twisted Evil :twisted:](./images/smilies/icon_twisted.gif)
Pretty much all 90degree VF's are between a TD04 and a TD05. The VF12 is the biggest of the 90 degrees, but it's still not that big of a turbo.Project_Legacy wrote:heh im gonna agree too. if you are changing the turbo, you might as well get an intercooler on it too since your alrdy there. plus isnt the vf12 sort of in between a td04 and td05? i wouldnt run that any higher than stock boost either. right now im boosting close to 11-12 psi un-intercooled on my vf11. i wouldnt go any higher than that on my setup.
