just wondering if some 2006 legacy suspension would work in my 93 legacy wagon? could i use my perches if the springs are different? i am running factory suspension and was told that i need to replace it.
thanks,
brodie
06 legacy gt sedan suspension in my 93 legacy wgn?
brodie.gordon
greg donovan
Starting in 2000, the Legacy uses a multilink rear suspension. The Impreza is likely going to this setup in its next big revision as well.
Legacy Central
Yup, the descriptions I've seen for that are "a shortened wheelbase version of the new Legacy chassis".DLC wrote:Starting in 2000, the Legacy uses a multilink rear suspension. The Impreza is likely going to this setup in its next big revision as well.
1994 & 2005 Legacy GT Wagons
That is exactly what the original Impreza chassis was...Yukonart wrote:Yup, the descriptions I've seen for that are "a shortened wheelbase version of the new Legacy chassis".DLC wrote:Starting in 2000, the Legacy uses a multilink rear suspension. The Impreza is likely going to this setup in its next big revision as well.
