06 legacy gt sedan suspension in my 93 legacy wgn?
brodie.gordon
Post by brodie.gordon »
just wondering if some 2006 legacy suspension would work in my 93 legacy wagon? could i use my perches if the springs are different? i am running factory suspension and was told that i need to replace it.
thanks,
brodie
greg donovan
Post by greg donovan »
nope, the rear suspenion is totally different between the two.
the 06 has a very small comapct multilink setup.
96 Impreza L sedan
97 legacy outback limited
00 Impreza RS sedan
DLC
Post by DLC »
Starting in 2000, the Legacy uses a multilink rear suspension. The Impreza is likely going to this setup in its next big revision as well.
Legacy Central
Yukonart
Cradle Robber
Cradle Robber
Post by Yukonart »
DLC wrote:Starting in 2000, the Legacy uses a multilink rear suspension. The Impreza is likely going to this setup in its next big revision as well.
Yup, the descriptions I've seen for that are "a shortened wheelbase version of the new Legacy chassis".
1994 & 2005 Legacy GT Wagons
Brat4by4
Stratified
Post by Brat4by4 »
That is exactly what the original Impreza chassis was...
