I was wondering, has anyone tried placing the stock maf at or near the TB on a turbo setup (blow-through setup) instead of before the turbo (draw-through setup)? I know on dsm's, we can run a 3.5" GM MAS like this, but it needs a translator since the bung is different then the dsm's. Since the air is metered right before the TB instead, this allows for better saftey (if an intercooler hose blows, the car won't bog since the metering is right before the TB). If your ricey, you can vent without issue since it will not cause a rich issue between shifts.
Since I'm running an N/A ecu, this seems theoretically possible since in an N/A stock setup, that's how it's installed isn't it? MAF->Intake Hose->TB. Sounds plausable. Guess I could always try it myself and post results. Anyone?
Has anyone install a stock MAF at the TB on a turbo setup?
Subaru Impreza Ver6 replica with Ver4 Type R motorset.
Mitsubishi Evolution 4 replica with Evo4 GSR motorset.
many of the High HP cars PDX tuning does I think do that. Are you searching on NASIOC in the conversion forum? There is lots of support over there...
Read this:
http://bbs.legacycentral.org/viewtopic.php?t=26324
Read this:
Retired but still rocking a 98 Coupe with the heart of a turbo legacy :)
sammydafish
my car is like this... I turboed the NA so it worked better for my setup.
- Junior
90L Wagon EJ22E on Toyota CT-26 boost -- Crushed!
95L Wagon on T3/T4 boost :)
www.trdsupra.com [b][url=http://trdsupra.com/library/forsale/]Cheap parts![/url][/b][quote="Imprezive"]alright, I give up, I'm going to NASIOC...[/quote]
BAC5.2
We work with a lot of blow-through cars. It gives you the flexibility of MAP for packaging, but all the benefits of MAF based fueling.
I'll probably go to a blow-through when I rework the motor.
greg donovan
