kelley i've been searching the board since you told me about this car on sunday... it looks AMAZING!!! so clean. what turbo did you end up going with? is it going to be done for the WCLCM?
Yukonart wrote:Is that really an RA motor, or did you guys just paint the valve covers?
And please tell me what you're going to do for a front bumper beam.
those are 02ish WRX heads and manifold, so yeah, they're just painted gold.
are you gonna be able to get the bumper back on? cause i made those same cuts below the lights, and i couldnt get my bumper back on. so i went down and around. either way yours looks great.
-93 2.2T (RIP), 93 N/A best car on earth.
-00 legGT, 18" PIAA sport mesh wheels, front/rear Rallitek sways, lowered whitelines, coming soon: 2.5L sti internals, 20g heads P&P, twin charged. motor is almost ready to go in.
Andrew
I tried to keep the bumper beam. I cut it down to the point of where it was just dead weight. I couldnt move the pipes any lower, cause you run into the frame rails, have to go around them, and then have the usuall setup anyway. Running them this way probablly bypassed a good 3 or 4 feet of pipe, and many bends.
I was looking at tilting the radiator back too and going that route on my own car, (I pulled out my working AC the day I got it) but this turned out to just be way more simple and straight foreward. I put flexible joints at the core support to allow for movement, thus making 7 flexible joints in the system. I think next time I'll do solid pipes all the way, thus making less joints to pop under heavy boost, prolly on my own car.
I dont have any more pics of the car. It was put on a flat bed today before I could snap some shots of it with the bumper cover on. The turbo is the same GPMoto twin scroll setup thats floatin around the 400hp+ crowd. Or search for my twin scroll header pics here.
The point of the thread is to show a different way of pipe routing. It can be much shorter, and straighter, and since I fucking hate NASIOC, I thought Id share here. Danke.
rallitektech wrote:The point of the thread is to show a different way of pipe routing. It can be much shorter, and straighter, and since I fucking hate NASIOC, I thought Id share here. Danke.
It's definately shorter than normal, but you can make it even shorter and straighter! Go for broke.
Rio Red 90 Legacy LS AWD 174k
Liquid Silver 92 SVX LS-L 88k
