A quickie on Top hats
Subaru for Life
Post by Subaru for Life »
Hi all, I came across a set of '02 WRX strut assemblies with really low miles and decided to put 'em on my '93 L N/A FWD. The front assemblies should bolt right on, but the rears I'm going to use my existing top hat assemblies.
My question of the day is, do the top hats including the rubber dampener wear out with age? I'll change 'em if I have to, but rather not if it isn't a wear and tear item.
Thanks in advance,
Pye
Yukonart
Cradle Robber
Cradle Robber
Post by Yukonart »
I feel let-down . . . came in here expecting to see some sex on the front fender of a car. :(
1994 & 2005 Legacy GT Wagons
As long as the rubber is not damaged, is pliable, and in decent shape, you should be good to reuse them.
Subaru for Life
Thanks Josh, you always pull through for me every time. I really appreciate it.
And Yukonart, sorry I let you down :P . But if you'd give me your email addy. I could definitely send you some of my collections on the fender :twisted:
Yukonart
Cradle Robber
Cradle Robber
Post by Yukonart »
:lol: It's all good, I'll survive.
Removing the strut top bolt can be a bitch, especially if it's crusty. I had to use an extra vise-grip to hold onto a tophat stud for leverage. It messed up the thread, but I replaced it anyway.
Advice: use a vise to hold the strut assembly if you plan to re-use top hats.
Subaru for Life
Actually I was thinking of using a pneumatic impact driver, after I put on the spring compressors of course :twisted:
What do you all think?
