Hi all, I came across a set of '02 WRX strut assemblies with really low miles and decided to put 'em on my '93 L N/A FWD. The front assemblies should bolt right on, but the rears I'm going to use my existing top hat assemblies.
My question of the day is, do the top hats including the rubber dampener wear out with age? I'll change 'em if I have to, but rather not if it isn't a wear and tear item.
Thanks in advance,
Pye
A quickie on Top hats
Subaru for Life
As long as the rubber is not damaged, is pliable, and in decent shape, you should be good to reuse them.
Subaru for Life
Subaru for Life
