Are they the same? I don't want to go out to my car and start a fire to figure out, but I'm wondering if my EJ22T injectors will fit in the NA rails.
If not, I can just swap the rails, but, I'd rather not have to. any clues?
92-94 EJ22T vs. 90-91 EJ22 Injector differences.
#82 M4 TRSCCA Rallycross
No they are not the same at all. You need to swap rails.
Also, they are 270 cc (NA) versus 370 cc turbo
NA 90 and 91 rails (Hitachi EMS) is the same as turbo rails. They should have grey injectors. The 92+ NA rails (Jecs EMS) are different. They should have red injectors. The newer Jecs rails will fit Nissan and newer Subaru side feeds. The Hitachi injectors are special an don't interchange with anything else I know of.
- Junior
90L Wagon EJ22E on Toyota CT-26 boost -- Crushed!
95L Wagon on T3/T4 boost :)
www.trdsupra.com [b][url=http://trdsupra.com/library/forsale/]Cheap parts![/url][/b][quote="Imprezive"]alright, I give up, I'm going to NASIOC...[/quote]
