92-94 EJ22T vs. 90-91 EJ22 Injector differences.
scuzzy
Post by scuzzy »
Are they the same? I don't want to go out to my car and start a fire to figure out, but I'm wondering if my EJ22T injectors will fit in the NA rails.
If not, I can just swap the rails, but, I'd rather not have to. any clues?
#82 M4 TRSCCA Rallycross
douglas vincent
Post by douglas vincent »
No they are not the same at all. You need to swap rails.
Also, they are 270 cc (NA) versus 370 cc turbo
scuzzy
Post by scuzzy »
douglas vincent wrote:No they are not the same at all. You need to swap rails.
thanks!
Are you sure they won't fit, Doug? The parts guide says that all 90-91 fuel rails were the same.
sammydafish
Post by sammydafish »
NA 90 and 91 rails (Hitachi EMS) is the same as turbo rails. They should have grey injectors. The 92+ NA rails (Jecs EMS) are different. They should have red injectors. The newer Jecs rails will fit Nissan and newer Subaru side feeds. The Hitachi injectors are special an don't interchange with anything else I know of.
- Junior
95L Wagon on T3/T4 boost :)
Some Nissan models use injectors shaped like 90-91 NA Legacy injectors.
