Installed a dual stage Nitrous setup....
douglas vincent
Well, I just like to go faster in a straight line, so sue me!
I have had a single nitrous setup for a long time, but have purchased over the years ALOT of nitrous parts. Enough to nicely put together a second nozzle into the intake.
I set it up so that I have the first nozzle spray at WOT (via a switch activated by the actual throttle). This first spray is to help my launch. I need a tad more power to get down into the 1.7 60' times.
Then I have a button nozzle that works ONLY IF the WOT nozzle is also activated. This prevents accidental button pushing. It also allows me to blow a fuck load more nitrous into the motor!
I tested it tonight with just a 20 dry shot in the WOT and a 50-60 shot on the button. FAST. But was only testing in 3rd gear and above. That Infinity G35 really probablly didnt know why I was catching them at over 90 mph on a closed course on ramp!
But the WOT nozzle was barely noticable. So I have switched to a 50-60 shot at the WOT and the button. Kind of scared to try it....
But I will find out Saturday at the dragstrip. Mid 13's are a given. Lets see how low I can go.... Technically a 12.99 is possible, but I doubt it.
thefultonhow
Re: Installed a dual stage Nitrous setup....
douglas vincent wrote:That Infinity G35 really probablly didnt know why I was catching them at over 90 mph on a closed course on ramp!
-- David
1990 Subaru Legacy L+ 4WD Wagon 5MT, white with 66k miles -- SOLD
[url=http://www.g20.net/forum/showthread.php?t=66214]1992 Infiniti G20 5MT[/url], White Sandstone with 175k miles
douglas vincent
douglas vincent
DO NOT add compressed oxygen to you engine. I can't remember why but I think it resulted in BAD THINGS happening....
BAC5.2
I was in a built-motor station wagon the other day that had a 100 shot, direct port nitrous injection.
Holy shit.
Holy shit.
douglas vincent
BAC5.2
douglas vincent
I recounted my time slips. It was my 8th pass on the bottle, with some freeway "testing" before hand. ie, the bottle was half empty. At PIR this coming weekend I expect to pull a sub 13.5.....
wiscon_mark
thehookeup
the whole oxygen thing is because of heat. @ 1500 degress nitrogen and oxygen separate. at that point you can burn the oxygen and the nitrogen absorbs the heat.
i have only seen one oxygen injected motor and it was a 454ci camaro, and the block and heads were worth like $30,000 i guess.
oxygen might work if your do a water injection with it. but i wouldnt trust our aluminum heads to that kind of rapid head increase and rapid decrease. but if could get it to work with oxygen that would be bad ass.
and doug you do have the fastest boosted NA in the northwest.
-93 2.2T (RIP), 93 N/A best car on earth.
-00 legGT, 18" PIAA sport mesh wheels, front/rear Rallitek sways, lowered whitelines, coming soon: 2.5L sti internals, 20g heads P&P, twin charged. motor is almost ready to go in.
Andrew
Andrew
DV - This is wicked! Please post photos of your setup. Thanks, Adam
douglas vincent
I have a purge solenoid, but its currently sitting in a box.
I will post some pictures as soon as I get some that are OK.
douglas vincent
Looks like a monster's crawling out of your engine bay through your hood!! Hopefully you've got some giddyup there to go with the looks! Cheers,
