Got my heads back
Got my heads back
Had them surfaced and cleaned. Next stop valve job and delta cams
Are those EJ22t heads? If so what year?
I ask because the EJ22t heads I took off have different coolant passages.
Ej22t on left. Ej25d on right.
You see that the coolant passages match.
1997 White BG Ltd 5MT, EJ22T with Wiescos, EJ20R Heads, Two large dents R.I.P
1995 Impreza EJ22T DOHC Hydra EMS, 20g, EWG, 3in APS TBE, AWIC
