Radiator fans won't turn on.
I had problems with the engine overheating and leaking oil so I pulled the engine. After putting it back in, I realized that the radiator fans don't turn on. I replaced the coolant sensor and it didn't help. Any other ideas?
///M
'93 Legacy SS - part out
just a thought... maybe a blown fuse? i know ive also had a problem of the fan clips not wanting to connect all the way
93 White Legacy Turbo Wagon: For Sale-ish
93 White Turbo Sedan: soon with a little more umf
91, funky brown purple gray color, legacy L Wagon: the "its so cheap i cant not pass it up" purchase to get me around when the others are down
- quasi-mod-o
Yeah, I was going to suggest a bad relay. Call me if you want to come by my place and scrounge for relays...dzx wrote:I'll probably go to the junkyard and get some relays.
2000 2.5RS daily driver.
1999 2.5RS w/ 50+ extra whp
Suby Hai!
Suby Hai!
turned out it was being caused by a couple of reasons.
1.) there was only water in the radiator, so it tended to boil out before the fans kicked in.
2) the exhaust melted the solder that i put on one of the fan harnesses when i replaced it, causing it to have a bad connection.
///M
