Possibly looking for a BROKEN pres. exch. solenoid
With the bigger turbo, the stock solenoid won't work, and I want to do the resistor thing to make the ECU happy.
I'd like to make a plug n play harness, and don't really want to cut up a perfectly good working PES. Anyone have a broken one??
Or possibly know of a similar style connector somewhere else on the car?
mikec
Post by mikec »
Why won't the stock pressure exchange solenoid work with the TD05?
Splinter
Post by Splinter »
Because the stock sensor only reads up to 13.7PSI or something
mikec
Post by mikec »
But that's not the pressure exchange solenoid. That's the MAP sensor.
Splinter
Post by Splinter »
I thought it was an integrated unit?
free5ty1e
Post by free5ty1e »
MAP sensor reads pressure provided by PES, which switches between manifold pressure and atmospheric pressure.
-Chris
91SS 4EAT stock, 200k mi
Splinter
Post by Splinter »
I know what each of them do, I just thought it was two parts of the same unit.
mikec
Post by mikec »
Nope. Sorry, but my original question still stands.
Blackbart
Vendor
Vendor
Post by Blackbart »
I went through my "Box-O-Harness-Plugs", and I don't see anything that would work other than the original plug on the unit. I don't have a broken one but it can be arranged, :smt047
I'm sorry....I called it the wrong thing.....it's the wastegate solenoid that I want....not the PES.
The PES & boost sensor will work fine....it's the stock wastegate control that won't really work right, since the the ECU want's to cut boost at 8.7 psi....and the wastegate spring doesn't open until 11 or 13 psi.
Anyway....I was looking at things this weekend, and turns out the wastegate solenoid & tranny resistor have the same plug, so it should be pretty easy to tweak things.
napphappy
Post by napphappy »
You can plug the resitor in directly where the Waste-Gate Soleniod was and it will keep you from getting a CEL. Careful it gets HOT.
1997 White BG Ltd 5MT, EJ22T with Wiescos, EJ20R Heads, Two large dents R.I.P
1995 Impreza EJ22T DOHC Hydra EMS, 20g, EWG, 3in APS TBE, AWIC
