Rebuilding 5MT
Splinter
Rebuilding 5MT
Post by Splinter »
Having some trouble cracking it open.
Ive got all the necessary bolts off the center diff (I think!) but its still not coming off, Ive run a credit card all the way around and the gasket is totally off.
Pics:
Splinter
Post by Splinter »
Got the diff off... but now I cant get the tranny halves to seperate. Gonna take a look through the FSM...
But it doesnt look good :s
Splinter
Post by Splinter »
So I found out where those teeth came from
Splinter
Post by Splinter »
So Im going to take the shafts to work on tuesday to see what can be done with them...
The front diff and rear diff are in the trunk of the legacy, do I need to be worried about anything rusting?
legacymax
Post by legacymax »
looks like you are going to need a new upper shaft. i would suggest finding a used legacy or impreza 5spd either for a replacement or to replace the parts you need. good luck.
-max
95 impreza Rally car. 3.0 H6
88 Toyota fj62 OME lift.
Splinter
Post by Splinter »
I supposedly have a new tranny coming... we'll see if he pulls through or not tho
But I work at a subaru dealership, so Im bringing in the fucked shafts on tuesday and see what the mechanics say
douglas vincent
Post by douglas vincent »
Mechanic will say "buy a new tranny"
New gears are super exspensive, and 2nd gear is only availble from Japan. I know. At least if its the NA tranny.
Yes, time for a new trans. Ever seen the prices for that much hyped STi RA gearset? Ridiculous.
You would need a main shaft & matching 2nd gear for the driven shaft.
THAWA
Post by THAWA »
What's wrong with 2nd?
Rio Red 90 Legacy LS AWD 174k
Liquid Silver 92 SVX LS-L 88k
THAWA wrote:What's wrong with 2nd?
There's no teeth left ;)
Binford
Post by Binford »
Yes there is :wink:
Binford wrote:Yes there is :wink:
On the main shaft? From the pic, there sure doesn't look to be any....maybe in the tranny case.
Binford
Post by Binford »
Sorry, I'm not trying to be a dick, but that looks like first gear to me. Second looks to be ok.
Splinter
Post by Splinter »
yea... 1st gear is blown, second is fine.
Blown 2nd looks like this
Binford wrote:Sorry, I'm not trying to be a dick, but that looks like first gear to me. Second looks to be ok.
You're not being a dick, you're just correcting me :)
Binford
Post by Binford »
:D
BAC5.2
Post by BAC5.2 »
Needed: New Input Shaft. New Output 1st gear.
Source? What tranny is it? Not an SS tranny, but definately pre-99. So probably an RS tranny. RS gears are easy to come by. But WRX gears don't work (syncro hubs, and thus shift collars changed after 99).
RA gears are the biggest waste of money anyone could comprehend. Can you imagine spending $1500 on OEM gears? You buy them, install them, that brings the bill to $2250 (plus tax and shop supplies, gears and labor only, no syncros).
You've now spent $2250 on gears that are no stronger than a stock set of 03.5+ WRX gears (which I have seen broken with stock WRX power).
It's a tough bullet to bite, to spend twice that on a REAL built transmission, but then again, you know you won't be spending the money twice... Blow a set of RA gears, and you have now spent MORE than it would have cost to do it right the first time.
Splinter
Post by Splinter »
huh?
BAC5.2
Post by BAC5.2 »
Just unleashing all of my pent up anger and frustration about the fact that people STILL waste money on RA gearsets.
Splinter
Post by Splinter »
This is what I dont understand:
NICO
Post by NICO »
FUCKKKKKKKKKKKKKKKKKKKKKKKKK
i just blew up my tranny. splinter wiat till you see how!! so mad it, had around 600,000kms 350whp.
got to show you this stupid stupid thing i did.
Bane
Post by Bane »
hold on a sec Nico... between Sat night and last night?
what the hell happened??
lol, told you not to let your brother drive it while we working on mine!!!
i remeber you saying 2nd was a bitch on your car... did you suspect something was going to happen, or just poof? no more 2nd at all?
James L
'07 Magnum SXT - not stock
'93 Legacy Turbo SS - 5spd conv, vf34, intercooled, K&N, dual stage mbc 11/16psi, hks 3" turbo-back w/hi-flow cat, kyb's, ADR 18" rims w/225/35/18zr's, 7" touch screen w/race camera
snowboarded
Post by snowboarded »
NICO I WRX U wrote:FUCKKKKKKKKKKKKKKKKKKKKKKKKK
350 AT THE WHEEL???
[quote="Manarius "]Only flamers will get those. [/quote]
[quote="All_talk "]How many WHP will that give me? :)[/quote]
2010 Subaru Impreza 5mt 5 door
