I can't just sit here with a bad motor now can I?
douglas vincent
I had an extra block I bought a LONG time ago, and all the parts are here.....
So 2 1/2 hours ago I started building a replacement engine.
Rod and main bearings are in, and so are the pistons. I am using a turbo crank, rods and pistons from a closed deck block that I sold. The turbo pistons are all "B", and the current block has ABAB pistons so I am taking a chance on two of them.
I should have the motor just about ready to go in by tonight......
douglas vincent
Got the DOHC heads on. Busted one head cover bolt.
Tapped it out, but I need to find another weird bolt like that. I also need to find 4 head cover bolts that would normally go where the coil pack bolts go.
I will install the manifold tommorrow and try to solve the throttle body problem, which is that the 2.2 body doesnt fit like the 2.0 does.
douglas vincent
Ready to swap!
Bought a new pressure plate and throwout bearing, just hoping the disc looks ok....
I will have to swap over the injectors, the flywheel, alternator and crank pulley, I think thats it!
douglas vincent
Its runs!
It drives!
I broke the exhaust header and its really LOUD!
And worse......I installed all new clutch components but must have screwed something up (suspect I installed the disc backwards) and so I need to pull the motor in the morning. Fuck.
It drives!
douglas vincent
douglas vincent
Bolts? What bolts? Damn thing is just swinging for now.
I suspect zip ties will be doing some work tommorrow. And I am currently using blue painters tape as electrical tape right now. HAHA.
I was given some Type N (?) motor mounts. THEY DONT FIT!!!!!!! You have to cut the nubs off. What a freaking hassle.
But...."Almost" everthing is working now. Its a matter of cleaning up the little things.
But I am going to make it to WCSS8!!!!!
wiscon_mark
