fuel gauge
subaru girl
fuel gauge
Post by subaru girl »
the fuel gauge in my 90 legacy always reads empty. where is a good place to start looking. is there a way to see it the low fuel light works.
Subaru's Are ForEver.
Me and My Husband Have :
90 Subaru Legacy L FWD
90 Subaru Legacy L 4WD
78 Jeep Cherokee,Quadra Trac
Manarius
Post by Manarius »
The low fuel light most likely still works. The fuel gauge sender almost always stops working over time. There are two solutions that I know of:
1. Some people think running some fuel additive with tecron(sp) can clean up the contacts on the sender. I'm a little suspect to this idea, but it's worth a shot.
2. Replacement of the sender/contacts all together. Requires removal of the pump and some other bits.
You could just always figure out what your average mpg is with the trip and just go on that - that's what most of us do. Although, like I said, the low fuel light usually tends to work even though the gauge doesn't. Get it down to around 1.5 gallons (on a 20mpg average car, that's like 280 miles) and the light should go on.
Here's the wiring diagram.
http://www.main.experiencetherave.com:8 ... iagram.jpg
You may want to start checking continuity and see if you can narrow down the issue to wiring, or the fuel level senders.
subaru girl
thanks, i will have to check into that
