I have a 93 legacy turbo wagon
before last winter, i was having some starter problems and i found myself constantly having to hit the starter while turning the key to get the engine to turn over. I let the car sit over the winter and now i can't seem to get the car to start.
i have a working battery in there, but i can't get any power to anything except the power locks. when i try and turn the key the only thing i hear is a chime... i don't even hear a click for the fuel pump .. radio/dash/signals don't work either.
so i have come to conclusion that i might have blown a main fuse... except when i look for the fuse box i can't find it ... i checked the main fusebox under the hoodd to find everything was good. but where is the other fuse box ?
anyone have any other leads on how to diagnose this problem ?
i wanna avoid taking it to a mech as i want to fix the car up a bit before i try and sell it.. i just need it to be running.
thanks alot
-ped
electrical issue's car won't start
Born 2 XLR-8
Every year more than 2500 left handed people are killed from using right handed products.
Earn easy cash in your spare time by blackmailing friends
Dont steal, the government hates competition
Manarius
Kick panel box - driver's side basically on the wheel well inside the car.
hmmm. one time i had this problem. It was the connection cables at the battery, and they were not corroded, they just needled a little wiggle/twist/rotate slightly and re-tighten. try that too.
91 Legacy Sport Sedan 4eat
91crx si 165k
91crx Si 40.5k
85 BRAT Gl 140
97 SVX 74k
91crx si 165k
91crx Si 40.5k
85 BRAT Gl 140
97 SVX 74k
ok guys here's an update
i checked all the fuses they seem to be fine ( both fuse boxes ) but i still can't get the car to start
same symptome:
key in turn all the way, i hear a chime and nothing else works EXEPT the power locks....
could the battery not be powering eneogh juice ?
anyone with any advice please help me out
thanks
same symptome:
thanks
Born 2 XLR-8
Take a fused test light to the battery (+) and (-). Then put the test light probe on the starter (+) large gauge power connection and the other end to the battery ground. It should as bright as it was at the battery. Next have someone turn the key over while you check the starter ignition input, the small gauge single wire. If both have good power. Get a new,used rebuilt starter or rebuild it yourself. The contacts or solenoid is prob burnt out. You can remove it and hot wire or jumpstart the starter out of the car to verify its bad too, but keep in mind its not under load. Load being to turn the flywheel/flex plate over.
