ok i have a 92SS, i know i need to swap to the 90-91 rear spring perches for the rears, but the front... my 92's should work with the 04+ springs right?
all i have seen in the threads is about the rear suspension, not the front. please help me out.
Thanks,
Shean
04+ springs
The Scooby
04+ springs
1986 GL wagon
EJ'ed and Lifted
1986 GL wagon
EJ'ed and Lifted
The Scooby
Yeah they should work. I'm not sure if anyone has actually tried it though. What I do know is the rear 02-03 springs are straight like the 93-94 springs and fit into the top perches. I think it's safe to assume that they will also fit into the bottom perches. I have heard people say that any spring will fit into any strut.
What springs are $80? That's kind of a lot for a stock WRX springs. You should be able to find them for like $40. STi springs are too stiff for stock struts or even GR2s anyway.
The Scooby
The Scooby
The Scooby
Those are ricer springs. Do you care about handling or looks?
If you want the car to handle well, you need more than just a set of springs. The overall goal is to maintain a good contact patch by keeping the tire flat and on the ground. To keep the tire flat you basically need negative camber and a good amount of roll stiffness. To keep the tire on the ground you need good damping.
This means stiffer springs, bigger swaybars, an agressive alignment/possibly camber plates, and the proper struts to keep the tire on the ground.
There is a whole boatload of this information available online, and searching/checking the faqs on nasioc will turn up a bunch of good information.
Spending $200 on lowering springs is not the place to start,
