I have a carbon fiber dash in the car thus eliminating the stock cluster. How do I hook up a aftermarket gauge? What are the ohms? How do I check the ohms with having duel sending units?
Car= 1990 Subaru Legacy Turbo conversion
Walbro fuel pump/stock fuel tank/stock sending units
HELP???
Aftermarket fuel gauge for rally car??? HELP
The two senders are wired in series, so their combined resistance gives you an overall fuel level.
Check out this thread for the resistances
http://bbs.legacycentral.org/viewtopic. ... uel+sender
I don't know. You'll have to check the specs on various aftermarket gauges and see which guages have a resistance range that is similar to the stock.
Basically, you're looking for a gauge that responds to the following range
1.0 - 5 ohms when full, and
92 - 96 ohms when empty
IronMonkeyL255
http://egauges.com/vdo_mult.asp?Type=Fu ... ies=Vision
This would likely work. I believe the bottom-most option would be the correct one.
Rio Red '91 Legacy SS
