my legacy racecar
4subaru
my legacy racecar
Post by 4subaru »
I race this 90 N/A fwd on a 3/8 mile paved circle track.
Right after it got painted and stickered
This is before i got it painted, its nice to have weight to throw
around
This is after two years of racing it, slightly beat up
This is my third win in my first season with the car
legacymax
Post by legacymax »
sweet car man! Why did you choose a legacy for circle track? Although i don't know anything about circle track, has the legacy platform been working well for you?
-max
95 impreza Rally car. 3.0 H6
88 Toyota fj62 OME lift.
rallysam
Post by rallysam »
Wow, this is a new one! It looks like NASCAR with the tilted number on the side.
'00 Impr RS - sold
4subaru
Post by 4subaru »
legacymax wrote:sweet car man! Why did you choose a legacy for circle track? Although i don't know anything about circle track, has the legacy platform been working well for you?
-max
Thanks, the car originally belonged to my buddy's girlfriend's brother. Since I help build my buddy's car, he bought the legacy for like $50 and gave it to me to build up. Only needed a fuel injector to run great. Since the car is like a tank, any rubbin with cars and the wall I do doesn't really hurt the car. Only problem I run into is that after a race or two, I’ll strip about half of the front right tire down to the belts since the car weighs so much. I have finished 4th in points the last two years and I’m going against Eclipses, Integras, Preludes, and Celicas. Also I have found the car is more dependable then those other cars, I just check my fluids and add gas every week and it has never broke down on me.
magicmike
Post by magicmike »
"I know Cole....he always passes on the high side"
2007 Ducati 800ss - Current
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru GL Wagon
1987 Subaru Loyale
Brat4by4
Stratified
Post by Brat4by4 »
Are you always going the same way around the track? If so you could weld up some camber plates for the top strut mount to keep that wheel with lots of negative camber.
If that's allowed in the rules, of course.
There is another member in Michigan that does circle track with his Legacy.
livestrong14
Post by livestrong14 »
Are AWD cars allowed to race? Or do you have to be front/rear?
91 SS -Carbon Bronze Pearl
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
91 Rio Red SS- RallyX Project
93 AWD Sedan- FOR SALE!
DLC
Post by DLC »
That's very cool man, very cool.
Legacy Central
4subaru
Post by 4subaru »
in my class, it has to be fwd
206er
Post by 206er »
what sort of cars are you running against, and what are some rules for the class?
a friend of mine races 1/4 mile oval in a mini class with a old celica drivetrain in a chassis that is subframed and backhalfed.
I wouldnt mind trying some dirt track with a super beater.
livestrong14
How about Turbo/ Supercharged cars? What kind of suspension are you running on your car for circle track? Got any pics?
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
4subaru
Post by 4subaru »
It has to be a fwd 4 cyl N/A that is suppose to be all stock but the tech department sucks ass there so there are alot of guys cheating
Brat4by4
Stratified
Post by Brat4by4 »
If you search there was a recent thread about drilling out the knuckle to allow you to run 2 OEM camber bolts up front to effectively double the camber you can run up front. Or some crash bolts in the lower holes will allow you to get that extra camber you need. That will really help keep the car from running through tires so fast and give you extra grip.
