I'd like to just pull the engine/tranny from both, and put the legacy stuff in the impreza.
so far, what I've found is that the legacy is most likely a 3.9:1 final drive, and the impreza is a 4.11:1 final drive (can anyone verify this for me, my sources are WEAK search hits on various boards)
does anyone know if I can just keep the impreza axles and have them fit on the legacy transmission?
ideally, I'd like to get out of this as simply as possible, which seems to be.. pull engine/tranny/rear diff from impreza and legacy. put legacy stuff in impreza
does anyone know which driveshaft I should use?
which axles?
will I be able to plug the ECU connector from the impreza into the engine harness of the legacy and have it work? (the imp has a strange almost OBDII kinda setup)
anything I'm forgetting?
