~'92 n/a legacy 2.2 auto into '95 impreza 2.2 auto
0perose
Post by 0perose »
my brother bought a cheapo '95 impreza with a bad motor. we have access to an entire ~'92/93 n/a legacy.
I'd like to just pull the engine/tranny from both, and put the legacy stuff in the impreza.
so far, what I've found is that the legacy is most likely a 3.9:1 final drive, and the impreza is a 4.11:1 final drive (can anyone verify this for me, my sources are WEAK search hits on various boards)
does anyone know if I can just keep the impreza axles and have them fit on the legacy transmission?
ideally, I'd like to get out of this as simply as possible, which seems to be.. pull engine/tranny/rear diff from impreza and legacy. put legacy stuff in impreza
does anyone know which driveshaft I should use?
which axles?
will I be able to plug the ECU connector from the impreza into the engine harness of the legacy and have it work? (the imp has a strange almost OBDII kinda setup)
anything I'm forgetting? :lol: :shock:
yo mang, can I get a rootshell?
1991 N/A, 4eat, crazy lights, junk suspension, sticker wagon
1989 xt6 work in progress
0perose
Post by 0perose »
just went and picked up the donor legacy last night..
rethinking this.. it seems more likely to be a quick job if we just swap motors... any thoughts on this?
I've never had an engine separated from an auto tranny, so any words of wisdom would be appreciated
The axles should be interchangable.
The engine electrical harnesses will most likely be different.
The solution is to swap intake manifolds....assuming the bolt pattern is the same between the legacy & impreza heads.
You need to remove the flex plate bolts which have to be accessed from that little opening in the engine bell housing. A ratcheting wrench helps a lot. Also, make sure that the torque converter does not pull out of the transmission, and is fully locked/seated when putting things back together.
0perose
Post by 0perose »
Legacy777 wrote:The axles should be interchangable.
remove flex plate bolts before removing engine, I'm assuming?
I'm new to this autotranny thing :shock: :-D
0perose
Post by 0perose »
starting the swap this weekend!
wish me luck
Richard
Post by Richard »
Luck
0perose
Post by 0perose »
engine is ready to come out of the legacy, just have to drain the coolant and oil, take out the last couple bellhousing bolts, and unhook the motor mounts
that will probably get done today after work, and then this coming week I have a break from school so i will get the impreza stripped out as well
there is a post in the classified section regarding me parting out the rest of the legacy
tzedek
Post by tzedek »
Just swap the impreza intake manifold over to the legacy engine to be sure everything is plug and play. Enojy :)
