WTB fuel tank wiring harness
Well I'm pretty sure my wacky fuel gauge issues are due to the wiring in the harness, or possibly the connectors at the senders.
Does anyone have an entire fuel tank harness they'd be willing to part with, or at the very least the connectors so I can test to see whether it's the connectors or wiring.
Thanks in advance.
Thanks in advance.
Matt Monson
- quasi-mod-o
I've got one that came with one of my recent swap purchases. Josh, drop me a line if you need one. It's cut,but has both connectors on it...
2000 2.5RS daily driver.
1999 2.5RS w/ 50+ extra whp
Suby Hai!
Suby Hai!
Thanks everyone.
Matt,
I'll probably take you up on the connectors. If I'm lucky the problem may just be the connector, and I might be able to splice things in without dropping the tank. If not, I could just use my own wires, or pick up a complete harness from one of the other guys.
I'll shoot you a PM.
Thanks again everyone.
Matt,
I just took a look at the one that I have and the connector that is under the rear seat had a temperature problem at one point in time in its 176k mile life... so the connector housing is a little messed up. It looks like it was one of the pump wires not the gauge wires.
94 Silver Turbo Wagon 5MT/Walbro255/SS header/STi Gn Mounts/01 RS wheels
Well I rewired things last weekend, and so far so good. If I go through the entire tank of gas and not have any issues, it's a good bet to say that the wiring is bad.
I'd prefer to use a factory harness then the one I hacked up, so if anyone has a known good one from a USDM first gen legacy, I'm interested.
I would like it. Shoot me a PM on what you would like for it.
tank harness
The one I have is out of the car. The connector has been overheated but it is still functional. The ground is the one that overheated for the fuel pump. It too was bypassed outside of the connector. I can get you the harness PN from the tag it you are interested.
My main concern is that the wiring itself throughout the harness is good. I can bypass the wiring just for the fuel pump at the connector, but I'd prefer that the gauge & fuel light wiring work and the connector be ok.
Depending on what you guys want for the harnesses, I may just take both of them.
