Dynoed the Reddevil at Torquefreaks today.
douglas vincent
Post by douglas vincent »
retuned and testing with the new FMIC
192 whp and 212 torque. Pretty happy.
Yukonart
Cradle Robber
Cradle Robber
Post by Yukonart »
Not bad!!!! That's a lot of torque!
1994 & 2005 Legacy GT Wagons
douglas vincent
Look closely at the AFR graph in relation to the HP. Whenever the AFR starts to go in the lean direction, power rises, richer it starts to go down. I have it tuned pretty well so you don't see huge differences, but my last dyno run you really could see the differences between 13-1 and 11-1, about a 10hp difference.
206er
Post by 206er »
so the dashed line is your target AFR? kinda blurry, what is it?
what pistons are you running these days?
good torque curve. 8)
douglas vincent
I don't think its quite a "target" line, but its 13-1 or so....
The stock ej22t, with DOHC heads. Engine comp around 7.5-1....
Yeah, nice torque!
Imprezive
Post by Imprezive »
Yes, but you;ve shifted the peak torque up to higher rpm...
1988 4Runner RIP
2006 Suzuki DRZ400sm
2007 Miata
1994 Miata
2003 WRX Wagon
2016 Mazda 3
