Look closely at the AFR graph in relation to the HP. Whenever the AFR starts to go in the lean direction, power rises, richer it starts to go down. I have it tuned pretty well so you don't see huge differences, but my last dyno run you really could see the differences between 13-1 and 11-1, about a 10hp difference.
I don't think its quite a "target" line, but its 13-1 or so....
The stock ej22t, with DOHC heads. Engine comp around 7.5-1....
Yeah, nice torque!
