Snow is finally in the forecast here in New England, so I decided to take the time to give the SS a good going through as it's my only means of transportation in the white stuff (I have three other cars...one's broken and the other two aren't suitable for snow), and because I was going to be hogging up the garage for the next three months with my Camaro while I get it ready for the next Auto-x season.
I drained the oil and replaced the filter. When I went to fill the engine back up, I was surprised (read: ripping pissed) to find that my douchebag roomate had stolen a few quarts of my oil to put into his POS 1932 VW Golf. I was left with only four quarts, but considering the manual says the car has a 4.2 quart oil capacity, I figured I'd be fine (final words??). While the oil was draining I also figured it would be a perfect time to finally see why I was getting the occational CEL when I was on the highway, I pulled codes:
22 Knock sensor
32 Oxygen sensor
35 Canister purge solenoid valve
...nothing to be too overly concerned about, though I did plan to take care of at least the knock and oxygen sensor this weekend. I also checked my coolant and saw I was about 6oz. low (I have a small leak where the upper radiator hose connects to the radiator), so I topped that off.
I started the car up, checked for oil leaks - nothing.
The next morning I went out and let the car warm up for a good 5-min before driving to work, as it was extremely cold. Car started up immediately, without any drama, as it always does.
Once the car was at operating temperature, I drove it a little spiritedly as I was running late. I came to a point where there was a small straight away, opened it up a bit, and made sure to shift as I passed a group of kids so they could hear my SSQV BOV (they always get a kick out of it). I took a left onto a different street, so it was a 90 degree turn that I took at some speed. This street then is straight for a good 200ft and then turns 90 degrees to the right. It's a tough corner so I was slowing down (on the brakes) before I went into the corner, trail braked a bit (I'm going maybe 15mph-20mph at this point...it's like a tight 90 degree turn on any auto-x course), and then left it Neutral with no throttle input as I coasted through the corner.
Immediately and suddenly, as I cranked the wheel to the right to take the turn, my engine started making a LOUD, frightening (to me) sound. It kind of sounded like a belt sqealing at a much lower pitch, with what sounded like an extremely aggressive and violent lifter-tick being played through a megaphone (as I have never heard lifter tick this loud) mixed in. I gave the car a little gas and checked my volt meter (on my turbo timer) and saw that it responded appropriately. My power steering also felt dead on and didn't affect the sound, so it didn't feel like the belt was slipping (no A/C belt, so that was the only accessory belt to check). I popped the hood (probably waking up everyone in the neigborhood) turned the car off, and saw nothing that looked out of the ordinary. Being only 1.5 miles from home, I decided to limp it home. The car, although insanely loud, didn't seem to run any differently at part throttle (didn't really open i up for obvious reasons).
Yesterday I stopped by Subaru and picked up a new Alternator/Power Steering belt. When I got home last night, I checked the oil...I was about 2/3 of a quart low (Note: I didn't check the oil after I filled the engine up, so I have nothing to compare this number to), so I topped it off. Pulled the old belt off last night and decided to start the car without any belts to see if it still made the sound. As I suspected, it did. So I thought to myself, "Well...I don't think it's anything simple....time to check for the worst".
A compression check yielded the following. This is illustrated as you would see the engine working on it from the front of the car.
___Windshield____
I...............................I
I..145psi......125psi..I
I..140psi......105psi..I
I_____Grille______I
Is what I'm hearing piston slap on that front right cylinder? My thoughts are that the hard corner plus being low on oil lead to oil starvation, which caused that piston ring to eat it.
Please give me any input you guys might have as I'm at a loss of what to do. I can't afford (time wise) to pull the engine and rebuild it, so I'm thinking I might have to start looking for another car and start parting this one out.
