my engine swap
my engine swap
I am swapping a ej20g into my 94 touring wagon. I have already swapped a 91 turbo legacy 5spd into it with excedy stage 1 clutch. I bought a rotated turbo mount that i bought from rallitektech and also a vf39 turbo. I am having Matt Monson get my wiring for the coil on plug system figured out for me and i will be installing the engine this weekend and the early next week. Matt Monson with be modifying the wiring like snowjob did. I am then going to running an early ej20g legacy ecu for a couple of months and also be building up the support mods like the fuel system, FMIC, powerFC, and turbo for my hybrid engine going in this next summer. I wanted everyone to know what i was doing and i will be making a write up and taking a lot of pictures. If anyone has any advice on this particular project, it would be much appreciated. I have done quite a few engine replacements so i have that down, but i do need advice on some of the heater lines and coolant lines.
-Max
-Max
95 impreza Rally car. 3.0 H6
88 Toyota fj62 OME lift.
Matt Monson
- quasi-mod-o
Whey,
Now I don't have to document this or take a bunch of pictures, other than the obligitory group photo once both our cars, and Judd's are done...
2000 2.5RS daily driver.
1999 2.5RS w/ 50+ extra whp
Suby Hai!
Suby Hai!
Matt Monson
- quasi-mod-o
gt2.5turbo
hehehehheeheMatt Monson wrote:Whey,
93 White Legacy Turbo Wagon: For Sale-ish
93 White Turbo Sedan: soon with a little more umf
91, funky brown purple gray color, legacy L Wagon: the "its so cheap i cant not pass it up" purchase to get me around when the others are down
Thanks for the gift Kelly, that coolant tank is going to work great.
The three of our cars are going to be very fast. I just got it towed to the shop so i now i just need to get started on it. my friend has one project car in front of me in the bay line up, but i should be able to get started on it on monday.
-Max
-Max
Update: so the engine i was going to use has a damaged oil pick up so the short block is trashed. So, i am starting a careful rush build of a ej22t/ej20t hybrid engine. I decided if i am going to build this engine, i might as well go all out so i don't have to touch it again. I just ordered a set of eagle rods from slow-boy racing, and am also looking to buy a set of Wiseco pistons. I am going to use Cosworth rod bearings i am pretty sure and am not sure what main bearings i want to use yet, but i might just use stock.
As for the heads, i am going to do a stock rebuild and 3 angle valve grind. I just have to be careful with the valves as i don't want to have to order them from Japan. I disassembled my set and cleaned them up, checked flatness, now they just need to go in the ultrasonic cleaner before i build them.
I am not sure what thickness headgaskets i want to use yet and i don't think i want to fork the money to buy ARP headstud but we'll see.
Any comments would be great, thanks
-Max
-Max
So, looks like i will be building and installing the engine this next weekend. Final specs of the engine.
-EJ22t short block bored out to 97.5mm
-Standard crankshaft reground
-eagle rods
-Wiseco Pistons 97.5mm
-Clevit Main and Rod bearings
-Cometic Headgaskets .054in
Heads:
EJ20H heads
-cleaned
-rebuilt
-3 angle valve job
-reground valves
Wiring:
-JDM legacy ECU
-Black MAF
-Coil on plug spark
Other things:
-VF39 turbo
-WRX TMIC
-Rallitektech's rotated mount, stainless steel headers
-Custom preturbo intake pipe
-STI metal coolant tank- thank you Kelly
-95 legacy angled airbox top
-SVX airbox bottom(bolts on to legacy mount but uses clips).
I will post some pics when i am done, It has been a kind of crazy the last few weeks trying to get everything together and have probably spent way too much money on it, but it has made me get rid of a lot of parts and my car's going to be sweet!
-Max
-eagle rods
Heads:
EJ20H heads
-cleaned
-rebuilt
-3 angle valve job
-reground valves
Wiring:
-JDM legacy ECU
-Black MAF
-Coil on plug spark
Other things:
-VF39 turbo
-WRX TMIC
-Max
Matt Monson
- quasi-mod-o
YeahMatt Monson wrote:I guess I best get on that wiring then, eh?
-Max
OK, but the work is going on down in Denver. I have plenty of help and it is up to you if it is worth the drive to Denver. I will be doing some brake work up in FTC in the next couple of months. If you have anything to install, maybe we could have an install meet with a few other people.206er wrote:max if you want any help just give me a shout.
-Max
Ok, here is my build pictures
EJ18,20,22 Eagle Rods:
Wiseco 20cc 97.5mm dish pistons:
Bare 2.2t block, bored to 97.5mm, surfaced machined to .008in.
Crankshaft assy:
Pistons going into block:
Shortblock finished:
Cams going on:
Valve covers on and painted and baked with two coats of VHT wrinkle red paint:
Engine with exhaust manifold and turbo:
Major Parts List:
Eagle Rods were on sale at slowboy for 319 when i bought them. Make sure they are in stock. http://slowboyracing.com/shop.php?sid=&cat=1607
Wiseco Pistons kit. $450 I went with 97.5mm pistons, if I would have put two and two together and realized i had to bore the block anyways, i would have gone with the 98mm pistons.
http://www.importperformanceparts.net/i ... ubaru.html
Cometic headgaskets $55 for each side. part # W6319-2 .054 thickness, 98mm. http://www.importperformanceparts.net/
Boring and block machining= $190 Ridge Reamer in Arvada, Co 303 420-3543
Paint: VHT Wrinkle Red paint: Best price i found was on http://vht.carshopinc.com/product_info. ... 6288/SP204
I haven't gotten it in yet, but i can only work on it on the weekends so that is why it is taking so long, should have it almost all done next weekend.
-Max
Crankshaft assy:
Cams going on:
Major Parts List:
-Max
Matt Monson
- quasi-mod-o
Right. Taking so long. What is it? 40 days since you put up the thread? You make me look like a turtle...
Suby Hai!
Suby Hai!
Yes, but you haven't been driving a car with a 1.8L, 150K suspension, and a Sparco Evo for the last 6 months.
While great on gas, it will light a fire under your ass to get the a fast/comfortable car running again. My legacy is going to be waiting for its two sedan swap brothers for a few months it looks like from talking to judd and you. I should have my fmic and PowerFC by then.
-max
-max
Matt Monson
- quasi-mod-o
And i will help. And then drive my "finished" car homeMatt Monson wrote:I bought a FMIC yesterday. When I get to it, I will get all the way to it...
gt2.5turbo
and i will still be trying to come up with the money for parts haha.... soon soon soon
Matt Monson
- quasi-mod-o
Engine is in. Matt Monson came down on Saturday and worked on the wiring while i finished up the intake manifold. Then i installed it. All went well except for me installing one of my engine mounts backwards.
Now i just need to connect everything. That will wait till friday. The only other thing i added is a lightened Excedy flywheel(12.75lbs). So between the rods, pistons, and flywheel, i lost 8.25lbs. 7.25 of that being the flywheel.
