I've read the compendium and I've done a TON of searching and I still can't decipher which struts from which years will fit my car and stock springs.
I'm not looking to upgrade my springs but I would like to drop a set of AGX's in and I can't find anyone who sells 'em for 1990/1991. TireRack sells them for 1992 and up...do they work with my stock springs without modification?
1990 Legacy AWD NA - what fits?
voodoochylde
americanyouth
voodoochylde
kawikid20o2
90-91 legacy matches 2004 /2005 wrx spring/strut setup minus the tophat. You have a tapered rear spring as do these years as far as I know it should work.
~Justin
Edit: It is possible that the rears may need to be shimmed with washers before you put the tophat on...that is what I had to do.
~Justin
1992 legacy wagon 12psi
EJ22T Swap STi Fuel Pump
Emanage Blue LGT Struts/springs
www.ccsucarclub.com
www.ccsucarclub.com
