aftermarket turbo
93TurboLegacy
aftermarket turbo
i was wanting to know which turbo would be best for my car. has to bolt up. i have a 93 turbo legacy.
EJ22T
92whitelegacy
the only turbo that will "bolt on" is a tdo5-16g. from deadbolt enterprises. and thatll set you back about $1,000 .
http://www.boostplanet.com
92 ss 275k+mi, kartboy shifter/bushings, gauges. VRG3 FCD II, NGK I'4s, TDO5-16G 4" dp CAT-less 3"tbe 4.11 gears.
93TurboLegacy
kawikid20o2
I'm pretty sure it has the old 8-9lb spring but the ECU determines the boost level by adjusting the boost pressure solenoid.
Its not about the boost as much as the flow, and there is a pretty big difference between the VF11 and a TD05 16G.
1992 legacy wagon 12psi
EJ22T Swap STi Fuel Pump
Emanage Blue LGT Struts/springs
www.ccsucarclub.com
www.ccsucarclub.com
